Piston Rings
Hi All
I am still struggling to obtain parts and cannot seem to locate in Australia some piston rings for a Mahle piston 97.98mm for the Alusil bore.
Anyone know where I might try?
Glen
Glen
I got 98mm top rings from Total Seal. I had the 2nds and oil rings. These are not "gapless." They are correct for an Alusil surface. I've been very happy with the top ring as had broken stock rings previously. They said this ring was intended for turbo engines.
Here's the full quote:
PART# DESCRIPTION QTY PRICE EXTENSION
CUSTOM-CS-08 BORE _____ WIDTH ___ ___ ___ AP Inv.#_______Line# __ 1 $297.01 $297.01
101896 AP 038250 0585 150 C-33 STEEL TOP 8 $0.00 $0.00
212094 126 038200 0775 140 CAST COMP 8 $0.00 $0.00
LABOR CUT DOWN RING 8 $10.00 $80.00
CUTDOWN TOP SIDE TO 1.75MM 0 $0.00 $0.00
CUSTOM C-33 PVD C-33 APPLIED TO FACE OF RING 8 $15.00 $120.00
000176 OR 038200 1180 145 3PC OIL 8 $0.00 $0.00
END CSUTOM SET 3.820 1.5 1.75 3.0 4CYL 0 $0.00 $0.00
Wow! What a mess. A challenge is finding all the rings in the right bore, height and depth. Looks like they had to custom-machine the 2nds. Pricing was near $500 for a complete engine set. $25 for each top ring.
