928 Forum 1978-1995
Sponsored by: 928 Specialists
Belt tension light
Old 09-04-2017, 07:34 PM
Christopher Zach
Christopher Zach's Avatar
Originally Posted by Wisconsin Joe
Can you get the connector on the front of the TB cover loose? It's a bit of a 'toughie' to get off.
If so, check it for continuity to ground. That's where I plan on starting...
When I actually get to it.
So how does that connector come off? Does it snap on around something, screw on, slide on, bolt on, rust on? I tried pulling mine off and wound up pulling the whole rubber thing out of the belt housing. Annoying.
Unfortunately it was raining this weekend so I couldn't work on it. Next weekend I suppose, meantime I can start troubleshooting why none of the climate controls work....
Old 09-04-2017, 10:12 PM
Alan
Electron Wrangler
Alan's Avatar
So as others have said if you have PKT - the belt tension wire is usually simply connected to ground. If the belt tension warning ever comes on it most likely means that your connection to ground is intermittent (it CERTAINLY means nothing with respect to the belt - since it's not connected to any form of belt tension switch and this is the only thing that triggers the warning).
There is now an option (see the thread Ken noted) - to actually connect the belt tension wire in a way to give you some warnings with a PKT - but this is a new idea and must be implemented when you install the Audi tensioner - so you also certainly don't have it yet.
The 3 minute delay is built into the CWS and cannot be changed - it is to avoid spurious warnings at start-up.
Alan
Old 08-12-2018, 07:36 PM
beran earms
beran earms's Avatar
Bringing this up … again. I have not had any time to look into this until today, and I was wondering what the best way to test this wire is? I have not driven this car , (I'm having lots of life issues getting in the way) but I would like to pick away at some small items. If I remove the 90 degree shaped boot from the timing cover can I run a jumper wire from it to a ground to test it? If yes, and the light stays out, it seems it would be the connection behind the cover, correct? If it is then what can be done to correct it?
Old 08-13-2018, 04:39 AM
gazfish
gazfish's Avatar
As mentioned above, you need to ground the wire to stop the warning light. Unplug it from the cover and connect it to a nearby ground point on the car. Either cut the wire to do this or make a metal pin to plug in the end so it could be reversed in the future. Until you do that you'll get a warning light.
Old 08-13-2018, 07:15 AM
beran earms
Thank you gazfish, that's what I assumed I just wanted to confirm. I will try this tonight.
Quick Reply: Belt tension light
