You can use some silicone sealant and nobody will ever know.
^^^^^ !Yech! Anyone who looks at the car later, or tries to service the booster, will see the squeeze-out after they try and pry the booster from the firewall. Make a paper or cardboard gasket, make it pretty, and move on.
a numptee used blue silicone to seal the new booser to the firewall
I had to use a prybar to remove the booster to install the new black clutch MC feed hose
NLA gasket for the brake / brake booster reassembly
Good morning. I tried to order part number two on the diagram below from 928 international and they said it is no longer available and I have to fabricate one. Is there any specific gasket material that I need to use for this?
Tom please reread post 2 BTDT
Edit OK if you dont want to use manila folder,
NOTE this material is usually found inside one of your cabinets at home ....
then take a ride to your favorite FLAPS and buy a roll of gasket material.
\ When you get home, roll it out and let sit on a flat surface till it takes on a flat shape, might take a few days for this to happen,
then cut out the gasket.
