928 Forum 1978-1995
Sponsored by: 928 Specialists
Building a replacement cap for sealing headlamps after converting to HID or LED
Old 08-28-2017, 02:50 PM
  #166
rjtw
rjtw's Avatar
I'm in for being a guinea pig :-)
Can we even order these things off alibaba? Looks like a b2b site with minimum order requirements...
Old 08-29-2017, 02:29 AM
  #167
rjtw
rjtw's Avatar
At the risk of jumping randomly between topics, I re-adjusted my headlight aim tonight... and did my first extended night drive, re-aiming a few times until I was happy... and now with clean lenses and properly rotated bulbs all I can say is... WOW!! THIS IS WHAT THE H4 HEADLIGHT WAS MEANT TO BE!!
I initially had the headlights aimed quite low, with the cutoff perhaps 50 yards in front of the car, and felt quite unimpressed. Sure the light was bright, but at least prior to tonight the coverage seemed uneven with brighter and less bright areas on the ground. Maybe it was cleaning the lenses or just raising the aim a bit, but now I have the cutoff perhaps 125-150 yards out and have a bright, clean, very even pool of amazing light everywhere in front. Nice wide dispersion too. Did a lot of driving on different roads to make sure they're low enough to not blind cars in front. Super impressed, this is FAR better than with 55/60 halogens or even the higher 100 watt bulbs I once tried! No comparison at all. The LED makes this a completely different and far superior headlight... Really unlocking its potential after all these years!
Negatives? Not really any at this point. I do think that the beam pattern is not QUITE identical to what it was with the H4s. I think there does seem to be a hot spot at the base of the V in the pattern, which is arguably a good thing, and I notice a bit of a scalloping effect on the upper right (echoes of the multiple LED elements?) But overall any differences are insignificant and far outweighed by the quality and quantity of light.
I'm picking up reflective signs on the right at distance, and far more clearly than with the old bulbs... and high beam is a monster! My very nonscientific estimate is that I'm easily illuminating signs and at least parts of the road a half mile ahead. Probably double the effective range of the 55/60s. In fact the reflection from signs straight ahead on high beam can itself be blinding! Ouch!
Super happy with the conversion. And SUPER happy with Ed's kit, without which I would never have even touched LED's. So for anyone on the fence, I give the whole package a HUGE thumbs up! And of course, I have no financial or other interest in any of the above. Thanks Ed!
Questions: Do folks aim L and R beams to converge at some point or leave them parallel? I used a straightedge between the lenses to aim them parallel, and they appear to be perfectly parallel. I like it this way but can see how beams set to converge could give better coverage at the convergence distance. Also just curious but is there a standard or other recommendation for vertical aim applicable to the H4s? Curious how the lights were "intended" to be aimed.
Rick
Old 08-29-2017, 03:33 AM
  #168
bogdann
bogdann's Avatar
Hi
The article in the link shows the correct adjustment for headlights.
http://www.danielsternlighting.com/tech/aim/aim.html
Regards
Norm
Old 08-29-2017, 12:45 PM
  #169
Ed Scherer
Ed Scherer's Avatar
[more commentary trimmed]...
Thanks for your enthusiastic comments, Rick.
Follow the link that Norm provided in the previous post and that I quoted again below vvv. It provides an answer to your question, along with all the other details for proper headlight aiming.
Originally Posted by bogdann
Hi
Thanks for providing that link here, Norm. It's the same document I reference in the H4 sealing cap installation instructions [as separate pages | as a side-fold booklet].
Old 08-29-2017, 08:34 PM
  #170
geschwindig
geschwindig's Avatar
Default GOT EM!
Got the caps yesterday. On my way home I stopped for a jug of MILK. Got home, put the milk in the fridge and looked at the exp. date : 9/28! Cool! Then I went out to the mailbox, and BOOM! There's the caps! Haha! Porsche works in mysterious ways... (or is that the post office?)
Anyway, SHIPPED FAST - QUALITY PRODUCT - CLASS ACT !!!
Thanks Ed
Old 02-24-2018, 12:28 PM
  #171
SeanR
SeanR's Avatar
Having just installed this kit. A dozen thumbs up from me. Thanks a bunch Ed.
Old 02-24-2018, 12:33 PM
  #172
Michael Benno
Michael Benno's Avatar
Hey Sean, what bulbs did you end up using? How many lumens?
I installed my bulbs almost a year ago now and they are 3500 lumens each. Just curious what is the latest and greatest available lumens.
Old 02-24-2018, 12:37 PM
  #173
Ed Scherer
Ed Scherer's Avatar
Thanks.
Next batch is almost done.
Old 02-24-2018, 01:26 PM
  #174
Bigfoot928
Bigfoot928's Avatar
Originally Posted by Ed Scherer
Thanks.
will these work with euro S4 lamps?
Old 02-24-2018, 03:35 PM
  #175
Ed Scherer
Ed Scherer's Avatar
I think so. Do they look like the one shown in the first post in this thread? (with 8″ H4 lens) Are the original sealing caps the same as the one shown in the first post? If so, it should work.
Old 02-24-2018, 07:06 PM
  #176
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
Wow, Ed!!
I just finished the install/assembly of your product. I am so impressed! It is very well thought out, with great machining and well integrated parts. It fits smoothly and function perfectly. Whenever I think I could make something for other people, I will remember how great this item is, and how it is truly a labor of love.
Thanks so much,
Dave
Old 02-24-2018, 11:59 PM
  #177
Bigfoot928
Bigfoot928's Avatar
I will check in the morning and let you know.
Old 02-26-2018, 04:23 PM
  #178
davek9
davek9's Avatar
None of them.
I've seen that type elsewhere (e.g., Amazon), too. I don't have one to inspect (measure, etc.). The barrel on the heatsink side of the 3-tab flange looks like it might be too short (and perhaps larger than 22 mm in diameter) to work with the caps I'm currently making. These bulbs also appear to be not as bright (but they do look well designed), so I'm not all that motivated to look into them further unless somebody already has them and is convinced they're better than (or as good as) the bulb I was recommending.
I measured the SuperBright H4 LED's (12 LED's per bulb) and the barrel diameter is only 18mm, and the distance to the Heatsink is 8mm from the headlight Lamp mount (3 tab flange).
Given the pricing of the Lumileds(?) at around 70 bucks, I'll pick up some and use them in the 8" H4 Lenses, and allocate the ones I have to the 7" H4 Lenses
Thanks Ed, and please put me down for two sets.
Dave
Old 02-26-2018, 04:42 PM
  #179
Ed Scherer
Ed Scherer's Avatar
Dave
Good timing on this, Dave. I spent a little more time trying to compare photos and diagrams of the Super Bright LEDs LED H4 units to the LUMILEDs units and it wasn't looking promising. I had started to consider getting a set of the Super Bright LEDs unit any doing another design iteration to see if I could support them. For a while, I've thought about a more modular design where the center part of the cap could be a separate piece that could be changed out based on different LED H4 bases, but I'd need time to work on that design which (as you can see if you start reading at the beginning of this thread) can take quite a bit of time to do right.
I'll put those plans on the (way!) back burner.
Old 02-26-2018, 06:42 PM
  #180
davek9
davek9's Avatar
Yes I read through this and agree w/ the amount of work/time you put into this Ed
I just ordered the BroView's LumiLEDs
I see, the H3's as the next target
I found these and at 700 LM each, they may be getting better and the pkj should fit the 928 Fog's
Amazon Amazon
Thanks again!
Dave
Quick Reply: Building a replacement cap for sealing headlamps after converting to HID or LED
