confusing overheat
88 S4...Rad fans do not come on
engine eventually overheats even when I force rad fans on with A/C switch
Drivers side rad hose cool...passenger side rad hose and top of radiator very hot
Thermostat stuck closed? If so would this also keep the rad fans from operating normally?
thks in advance
thks in advance
Yes...the fan temp sensor is at the bottom of the radiator by the return hose, which is cold.
Ensure you replace BOTH seals for the thermostat.
Roger at 928srus will guide you on these -2- important thermostat seals when you R&R this.
Just a note: Just in case.
Do not remove the thermostat and run the car for any length of time....without watching the temp gauge....
These aren't our '70s GM/Ford/Chrysler cars.
Get a new T-stat and all the related bits, read up on the rear seal here on the list and carry on......
Last edited by 928 at last; May 15, 2016 at 10:23 PM. Reason: Missed North America reference...
