Throttle plate stuck 87 auto
I just replaced the bearings in the throttle body. I messed up a bearing trying to put it in so I had to use another one.
My throttle plate will no longer fit in the opening.
Is it possible that I deformed the opening so it is no longer circular?
I am at a loss as to why the throttle plate no longer fits. It came out fine.
John
John
Team Owner
OK do you mean the plate will not pass through the shaft slot?
If so then feed the plate in from the other side. see if that works
It definitely doesn't fit. Is it possible I deformed the opening putting the bearings in? You would think that would take some heavy duty force!
Should I file down the edges slightly? Will that allow too much air to sneak by at idle?
Former Sponsor
Measure the bore, if it isn't round any longer, you need a new (different) one.
Team Owner
when you put the bearings in did you freeze them and use heat on the housing?
This method works well to reduce the insertion forces.
From the looks of things the bore is out of round.
Former Sponsor
