Sadly, this is not the first time I've done this...
...trapped the closed end of a racheting wrench between a pulley and accessory by backing the bolt out.
#ugh
#ugh
Welcome......
welcome to my world......
And that right there...is why...after thirty eight years of wrenching for a living...I don't own a set of racheting wrenches.
I assume it can't be reversed without removal first? Do you have a pulley puller?
Good luck.
One of my favorite stories is about another mechanic I was working with and he was replacing the brake lines (steel) on a vehicle. Cars on the hoist and we're both standing there talking, while he is tightening the lines and union...with box-end wrenches.
Brian.
Good luck.
Brian.
Deputy you are missing out on great tools if you never try the Gearwrench type wrenches. They are great. I used to wrench for a living and wish they were around back then. All they had were crappy Craftsman ones that had too much travel and too much drag.
I did this during my timing belt adventure! Glad I'm not the only one...
Good luck.
Brian.
Good luck.
Brian.
Only done that once and I can't remember how I got out of it now but I do remember it took a long time to do it without cutting things up.
Still got 4 sets of non-reversible ratchet spanners including a premium set of friction based spanners that are the equivalent of something around 360 teeth geared ones
Under the Lift
