Does anyone know the dimensions for the "O" ring that is inside the stops that go on the steering rack outer members?
AFAIK it is only available as a part of the stop itself, (Item 3 in pic), which doesn't really make sense to me as an o ring /rubber product has a shelf life..
Thanks Kevin,
I think I am using the wrong nomenclature.
Maybe it isn't a bump stop at all and just an outer stop. It installs over the rack shaft and not on the actual tie rod arm..
I need the internal O ring size..
I may just try to match it up at the store, but our parts stores here leave a bit to be desired.
Thanks Kevin,
Thnx
John
You will not find it at a parts store. It is the bump stop.
