928 Forum 1978-1995
Sponsored by: 928 Specialists
85 928 Euro Brake Weirdness
Old 03-20-2016 | 05:15 PM
Erik Wilson's Avatar
Erik Wilson
4th Gear
Default 85 928 Euro Brake Weirdness
I am trying to restore my dad's '85 928S Euro that has been in my family since it was first brought to the States. Most things have been done and worked out pretty much as expected, but we have a new issue that before I dive in with all new parts I was hoping someone here could point out a good direction.
For the longest time the ABS light would come on intermittently. We changed the relay and then removed each sensor and flushed tons of crap out. All the sensors where put back in, none were replaced, yet.
Before this was done the brakes stopped fine, no ABS usually but they worked well. Now there is a lot of feedback in the brake pedal, the stopping distance is terrible and when you slam them the left front and right rear wheels lock.
Sensors? Module? Both?
Thanks,
Erik
Old 03-20-2016 | 07:07 PM
The Forgotten On's Avatar
The Forgotten On
The sensors are really hard to get used if they failed so I would unplug the ABS relay so you can drive the car, only without ABS like the earlier cars.
Old 03-20-2016 | 08:28 PM
Erik Wilson
4th Gear
The Forgotten On,
Thanks for the note. I have the same thought but I believe Pelican Parts has new sensors for like $200 each, which I'm considering doing just to make the car "complete".
Erik
Old 03-20-2016 | 09:15 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
Thanks,
Erik
I feel sorry for you guys trying to isolate ABS problems without a shelf full of "test" pieces, like I have....this can be a really tough road.
The most common intermittent problem is the short looms that run from inside the engine compartment to the front spindle.....if the problem is very intermittent, these can be tough to confirm being bad by checking continuity. As they deteriorate more, it gets easier.
Clean both of the relays on top of the ABS pump. Also clean the ground wire to the pump. Remove both of the wiring plugs to the pump and clean them. Make sure the electric motor for the pump runs....pretty simple to jump it and make sure.
For some crazy reason, rodents love the loom that runs to the ABS pump, along the inner fender. When the inner fender panel is out to clean the relays and ground wires, check that loom....it is common for it to be damaged.
Clean the main power relay on the fuse panel. Test it and make sure that it works.
Clean the main power fuse to the relay and contacts, while you are there.
Make sure you have power coming out of "87" on the ABS relay, when you are done. (H25 on a US car.)
Old 03-20-2016 | 11:27 PM
Erik Wilson
4th Gear
Wow Greg thanks for the details. Really appreciate it.
Erik
Quick Reply: 85 928 Euro Brake Weirdness
