928 Forum 1978-1995
Sponsored by: 928 Specialists
rebuilding 928 front end
Old 03-17-2016, 05:32 PM
Edwardoo928s
Edwardoo928s's Avatar
Default rebuilding 928 front end
I can't ignore the front end is getting old and looks to have never been serviced.
Can't aligned it with bad ball joints, tires wearing unevenly.
I'll do the work myself just like the TB and w/p I did last year. It's got 100 grand on the OD and I want to drive it more often.
Sooo what advice can you guys hit me with, I looked at the only video i can find on youtube. I might just do one myself, if I don't start cussing like a sailor.
Manuals i have.
Do you bother with replacing the upper ball or just by a complete A arm?
Is the original lower ball joints aluminum? what do you want steal?
For a complete front end rebuild kit, what did you pay for it?
Rodger is my guy for parts, "you got mail"
Thanks brothers I'll wait for your advice
Edwardoo
Old 03-17-2016, 06:10 PM
hlee96
hlee96's Avatar
Just did my whole front suspension with brakes. Alum lower ball joints have to go and be replaced with steel, but what year is your 928? If your upper/lower control arms are original, probably needs rebuilt parts from Mark/Tom from 928intl. $295/arm with separate core charge. Original boges should be changed out and Roger has them.
Here are some pics:
Aluminum on the left, steel on the right. Notice the shape of the metal bodies. Only need one replacement eccentric per side
Old brakes
Blasted then plated dichrom zinc
Upper control arm and spring-struts
Lower control arm
Old 03-17-2016, 06:35 PM
Ad0911
Ad0911's Avatar
I am sooo jealous because you have been able to find someone that can do the yellow plating on the calipers. I tried several here in the Netherlands but the process for yellow plating here doesn't stick to the metal of the calipers. Apparantly due to environmentally reasons the cadmium plating is no longer allowed here so they do a zinc coating with some second batch to make it yellow. The zinc just will not stick to the metal from the calipers. Now I had to spray paint them with caliper paint.
Old 03-17-2016, 06:52 PM
GuardsTurbo
GuardsTurbo's Avatar
Still looks great though
Old 03-17-2016, 09:40 PM
mkriete
mkriete's Avatar
Here is a good reference.
http://dwaynesgarage.norcal928.org/FrontSuspension.htm
I have replaced the lower ball joints, upper A-arms (from 928Int'l and worth every penny), rebuilt the brakes, replaced the dampers (I had a shop compress the springs). I have not done the lower arm yet. Mark the eccentric before you remove the ball joints. Generally, I just followed the work shop manual procedure.
The front PS nut on the upper A-Arm is hard to get to. I used a shallow 7/8" socket on a 3' breaker bar to break it loose.
Old 03-18-2016, 05:38 PM
Edwardoo928s
Thanks guys great advice, I'll start by ordering the Steel lower ball joints.
My laundry list is getting bigger
1985
Replacing the shocks to bogies and taking out the progressive springs too.
Old 03-18-2016, 05:43 PM
Edwardoo928s
This is the engine
Car was modified to S4 parts sometime in the past
This is an old picture it looks more stock today,
Old 03-18-2016, 07:01 PM
Wisconsin Joe
Wisconsin Joe's Avatar
If it's an 85, ball joints were already steel (not that replacing them isn't a good idea).
Quick Reply: rebuilding 928 front end
