1990 928 S4 oil check valve question
#31
Team Owner
maybe the PO that added the JB weld to the setscrew also scr4ewed with the spring
#33
At your own peril, you can do what I did. Use a dollop of grease/vaseline on a long q-tip. Stuff it down in the gallery, past the ball seat. Insure it seals the gallery below the seat. Use an HVLP spray gun SS or brass cleaning brush on a drill to burnish the seat. Don't go hog wild here. Connect a vacuum to a 1/4" metal line, and suck the goo out from below the seat. Keep sucking until all the goo is removed. That's about as clean as you can get without opening the oil pressure system and blowing out the galleries.
#36
Shameful Thread Killer
Oye - low oil pressure and rattling engine are not - a - good - thing.
I would say this issue is contributory, but there's likely something else going on. Maybe both check valves being hosed would do it. That gallery serves to cams and the lifters so without enough oil pressure in the upper deck area, you'll get some lifter rattle. Are you going to refurb both check valves? I would highly recommend it.
#38
#39
Team Owner
did you see if the ball seat is loose?
#41
When I put mine back in, I used a bolt and ground a point on it. I didn't want to have to fight the allen again. Run a die onto the threads of a small bolt, grind the point, the run the die back off to clean the threads. Make sure the o-ring is new, insert the plug all the way in and then screw the bolt in with some red loc-tite.
Let us know how the oil pressure reads and any clacking after the job on both sides.
