Rear light issue
Hey gang, 87S4 with driver's side marker (rear) intermittent on/off issue. I usually could tap on light and it would come on. Took it out to clean and now no light at all. Drivers taillight also out. Fuse looks fine. Any thoughts? Is there a fuse for tail lights? I don't see one on my fuse printout
Team Owner
FWIW there is also 2 white 2 pin connectors that are laying on the floor,
in the rear corners of the hatch, these get wet,
then corrode ,
they are for the side marker lamps
then corrode ,
Thanks MrMerlin. I got he the both to working. Passenger side was corroded. Took a wire brush and deoxite to it. They both come on with the switch. No more tapping on the lens to get them to come on.
