RacingBrakes.com 2 piece rotor performance after one season
#32
Former Vendor
Same disc size (322x32) but different offset. 993TT seems 6mm shallower than 928 GTS.
So it just needs a shallower hat for 993TT.
However our spindle in house indicates the offset difference between the two spindles is only 4.2mm, so we believe the caliper between 928GTS and 993 is also different in order to add up to a total of 6mm in difference if it's true and correct.
#33
they call that C2Turbo and those are the better calipers too than S4 because they are radiused to be used with the stock 322mm rotors , but the hats are the same and so are the calipers the same as , funny enough , S4 calipers. (little brembos)
#36
I just replaced the Racingbrakes.com rotor rings after almost 3 seasons of racing. i was truly amazed. they were much better than the first generation i had used , that still lasted a full season, but the new design is amazing. they had a HUGE impact of hub temperatures being lower, which translated to the rim also being much cooler. the pads lasted longer as well. Here is the near 3 season old rotor, that had some small cracks developing at the start of this season, but survived 2 race weekends at autoclub speedway, , laguna and sears point . i would have run them for a few more weekends, but the pads were getting thin and i wanted new stuff before the runnoffs. (plus, they are done now)
#38
The Racing Brake website shows the discs with the hats, and the description says “plug and play”. I was under the impression the discs and hats were included for the price.
#39
the 993 non turbo disc is the same as the S4 disk, but the hat will have a different offset.. the only offset we share with the 911s is the 964T. (which is a GTS rotor size equiv)
#40
Former Vendor
All 928 two piece rotors (304/322/330) use the same rotor hat:
https://www.racingbrake.com/category-s/7595.htm
Thanks to RB center mount design which makes 304mm rotor two pieces possible.
#41
#42
Former Vendor
Same hat can go up to 340mm rotor - RB 2pc Big Rotor Kit (340x32) for Porsche 928 S4/GT, GTS, 964 Cup, 964 Turbo Front Upgrade.
https://www.racingbrake.com/ProductD...oductCode=2483
In stock.
Weight comparison:
Size (mm) Wt (lbs)
OE 1-PC 322x32 21.0
RB 2-PC 340x32 17.5
In stock.
Weight comparison:
Size (mm) Wt (lbs)
OE 1-PC 322x32 21.0
RB 2-PC 340x32 17.5
#43
In stock.
Weight comparison:
Size (mm) Wt (lbs)
OE 1-PC 322x32 21.0
RB 2-PC 340x32 17.5
In stock.
Weight comparison:
Size (mm) Wt (lbs)
OE 1-PC 322x32 21.0
RB 2-PC 340x32 17.5
as a note, the 991 CS has 340mm front rotors and the 991GTS has 350mm front rotors and 330mm rears
#44
Former Vendor
It's for 928 GTS, not 991 GTS.
991 CS is 340x34mm and has different offset from 928, so the 340mm BBK upgrade is applicable to 928 with the same offset only.
BTW 340x32mm is the same disc of our two piece rotors for the new VW Golf R MK7 stock replacement.
