928 Forum 1978-1995
Sponsored by: 928 Specialists
My 1983 928S
Old 02-23-2016, 10:09 PM
tursch
8th Gear
tursch's Avatar
Nice car. how do you plan to modify the seats for more head room?
Old 02-23-2016, 10:57 PM
ANF
ANF's Avatar
Thanks.
I have a friend who has an 82 model with some extra, buggered seats. We looked at them and they have up to 3 inches of padding. I was going to fit this seat, take the foam out and then get some high density foam (cut to shape) and add in layers until I was comfortable. Then take my drivers seat to a trimmer, get them to match the height/ padding and trim to match the rest of the car. I think I should be able to get about 1 1/2 inches of extra room.
Old 02-24-2016, 04:08 AM
The Deputy
The Deputy's Avatar
Default Just a heads up...
When I bought my 84, the antenna was just like yours, not retracting all the way...and every morning the battery would be dead. Repaired it (by lubing the shaft and cleaning the motor gears) and life was good. The antenna motor continually tries to pull the shaft down, to the rest position, regardless of whether or not the key is on.
So, if you have a battery issue...look at that antenna. Plus, it looks better when it's full retracted anyway...lol.
Brian.
Old 02-24-2016, 04:22 PM
ANF
ANF's Avatar
Brian.
Cheers.
The aerial will most likely be made redundant, I will retract it and disconnect or even remove it.
Old 02-25-2016, 09:38 PM
STRIKEMASTER
STRIKEMASTER's Avatar
Very nice '83 and a right handed Euro too! Makes drive up windows kind of a problem though.
Old 02-25-2016, 11:33 PM
ANF
ANF's Avatar
Thanks. Not an issue - Aussie car in Australia (not that I frequent drive throughs)
All our cars are the "euro" spec/ or R.O.W.
Cheers
Quick Reply: My 1983 928S
