After 100 mile drive to phoenix in my 83 928 I noticed the fuel door was pushed open about 1/4 in. When opening gas cap it took 1/2 min for the pressure to drop along with loud wooshing noise. Is it possible that the vent to the tank is plugged? Thanks in advance.
There is a breather plumbed into the tank with a one way check valve ..allows it to inhale but not exhale. the PET parts diagrams will help you understand. The fuel pump was collapsing the fuel tank as the gallons of gas were not being replaced with air....
The purging valve for the charcoal can is different on early vs S-4 . Early uses a thermo switch rather than electric solenoid. In normal operation when it opens it pulls a small amount of air out of the tank which is replaced by the venting mentioned above. This fresh air purges any vapors from the charcoal can.
You need the PET showing the gas tank and overflow reservoir etc. in the rear.....
Randy V. I take off the gas off cap and gas fumes come out in a rush just like the tank is under pressure and not under a vacuum. I guess what I'm asking is if this is normal? I know this is a sealed system and all it seems excessive.
Speedtoys. do you mean the adjustable control valve going to the intake or the plastic diaphram unit back by the washer bottle? how would I test proper operation? Thanks for your help.
