928 Forum 1978-1995
Sponsored by: 928 Specialists
Strange front wing
Old Jan 26, 2016 | 05:53 PM
jas79's Avatar
jas79
Default Strange front wing
I´ve bought a used right hand front wing from a 1984 euro 928S. It has got a countersunk circle on the lower part, behind the wheel arch.
Do anyone know what it is used for? I´ve never seen it on another car. Is it possible that it isn´t an OEM part?
It is possible that the wing isn´t original for that parts car, because it is repainted.
File Type: jpg
Old Jan 26, 2016 | 06:14 PM
mark kibort's Avatar
mark kibort
is that the holbert front fender??? it had one
Old Jan 26, 2016 | 06:19 PM
Chuck Z's Avatar
Chuck Z
That recessed area is usually hidden behind lower rocker panel trim pieces found on later cars. Not sure if the 84 MY had the lower trim pieces so if not, the front fender you bought may have been replaced on the 84 at some point with a newer version.
Old Jan 26, 2016 | 06:42 PM
James Bailey's Avatar
James Bailey
show a picture of the area in FRONT of the wheel opening...
Old Jan 26, 2016 | 07:00 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
what you have is a fender from a 1987 S4 series,
these cars had the added on lower body cladding.
S3 and earlier did not have these indentations
Old Jan 26, 2016 | 07:12 PM
James Bailey
Correct .... so then it is missing the lower part of the fender in front of the wheel opening....which is why I requested a picture...
Old Jan 27, 2016 | 01:56 PM
jas79's Avatar
jas79
Some more pics...
Does the 1987 have different fenders than newer S4? The part in front of the wheel looks as it should on an 928s.
There´s also a question about the holes for the protective moulding. The holes are smaller than usual, so it is not possible to use the mounting bushes.
There is also a reinforcement in the front corner of the fender that i don´t recognize.
File Type: jpg
File Type: jpg
File Type: jpg
Old Jan 27, 2016 | 02:08 PM
James Bailey
Is there any evidence of welding body work on the inside of the front lower section ?? Possibly was an S-4 fender which had a piece of skin from an early fender welded on to mount the front spoiler ???? S-4 nose wraps around so fender is much shorter.
It is easy to modify early fenders by cutting off and adding a flange.
Old Jan 27, 2016 | 02:37 PM
jas79's Avatar
jas79
No signs of welding. I don´t think it´s a S4 fender welded together with an older one.
Old Jan 27, 2016 | 02:42 PM
James Bailey
well it is indeed a strange wing....that corner reinforcement was on later fenders as I recall and the dimple for the lower skirts is S-4 ..if only these parts could talk
Old Jan 27, 2016 | 05:19 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
In the first picture in post # 7 you can see the remnants of the S4 skirt - a horizontal crease in the paint.
Old Jan 27, 2016 | 07:32 PM
Jerry Feather's Avatar
Jerry Feather
Likewise in the picture in the first post, in the fender just aft of the wheel opening, as to the S4 rocker covering. But, none of this helps explain how or why there is the S4 indent in what is obviously an earlier fender.
Old Jan 29, 2016 | 07:57 AM
jas79's Avatar
jas79
Thanks for all ideas. This will stay as a mystery.
Old Jan 29, 2016 | 11:05 AM
kurt_1's Avatar
kurt_1
I used to be wrong before but I venture a very wild guess: could this be an aftermarket fender made of steel?
One of the pics seems to show rust around the lower hole on the outside of the fender. It could as well be contact corrosion between alloy wing and steel bolts
Try a magnet!
Kurt
_______
90 S4 satin black metallic
928 OC Charter Member
Old Jan 29, 2016 | 04:20 PM
jas79's Avatar
jas79
It´s aluminium, not steel. Has anyone seen aftermarket fenders for sale?
Mattias
__________________________
1986 928S auto (Preussian Blue)- on its way to a full respray this winter
1985 928S man (Grand Prix White) - waiting for care, hasn´t been on the road since 2003
