928 Forum 1978-1995
Sponsored by: 928 Specialists
Gap around headlight
Old Jan 24, 2016 | 07:17 PM
careful1's Avatar
careful1
Default Gap around headlight
I recently put a new fender on and noticed a gap around the headlight in the down position. Is there an inner piece to close the gap or is that normal? Seems like it would not be aerodynamic for such a gap.
Old Jan 24, 2016 | 08:53 PM
jbrob007's Avatar
jbrob007
Pictures? Hard to tell without them... take a few from different angles, especially if you can get both headlights in the shot.
Old Jan 24, 2016 | 09:56 PM
careful1's Avatar
careful1
It's hard to see the gap. You can see the light showing the holes in the plastic guard inside the wheel well.
File Type: jpeg
Old Jan 24, 2016 | 10:53 PM
Speedtoys's Avatar
Speedtoys
Seems about right..does the fender gap measure right and even where it should?
Hood, at the door, etc?
Old Jan 24, 2016 | 11:03 PM
careful1's Avatar
careful1
Yes, the fender went on perfectly. Thanks to the advice of you guys here. The other fender also has a gap. I just thought a gap around the lights was odd. I guess that it is not an issue.
Old Jan 25, 2016 | 10:18 AM
Jerry Feather's Avatar
Jerry Feather
Your car has only one headlight? It it had two you could compare with the headlight that is in the fender you did not change.
Old Jan 25, 2016 | 03:46 PM
careful1's Avatar
careful1
It has a gap also. The car looks like it had a respray at some time well before I got it. I hadn't noticed until I changed out the fender. My thought was that the Previous owner left something off .
Old Jan 25, 2016 | 03:59 PM
jbrob007's Avatar
jbrob007
Looks right. Raise both headlights fully and see if they seat in the same relative position and are not grabbing or rubbing with the fender. If everything goes up / down well, you should be good to go.
Old Jan 26, 2016 | 03:34 PM
careful1's Avatar
careful1
Thanks guys
Old Jan 26, 2016 | 03:56 PM
James Bailey's Avatar
James Bailey
Porsche had to leave some clearance for snow and ice build up....since in their minds it was a car to be driven no matter what the weather after all snow wheels were an option. Plus it snows in Germany. They were not making show cars or collector pieces.....
Old Jan 26, 2016 | 04:54 PM
Randy V's Avatar
Randy V
25 Year Member
That gap can be minimized by adjusting the headlight pod stop position. Accessible behind the wheel well liner.
Old Jan 26, 2016 | 10:19 PM
careful1's Avatar
careful1
Again proving that the 928 rennlisters are the smartest group of enthusiasts with even the most obscure questions posed. Thanks guys.
