You guys with the 16v engines running the euro shorty headers: How are you bolting them up? Are you trying to use the factory studs or are you using bolts?
I am trying to use the factory exhaust bolts on my 1979 4.5 , but things don't line up just perfect as seen below:
The one hole is extra small, it seems. Are you guys just enlarging this one hole a bit and getting things to fit right? The manifolds seem to line up pretty close except for a few spots. It seems like enlarging the one hole might set things right. Am I right?
As for the new manifold lining up evenly over the exhaust ports, no problem there, the holes in the euro shorty manifold are considerably larger (43mm) than the 4.5 exhaust port (36mm).
Reason: forgot things
I slotted all the holes a little so that I could centre the whole header better, and make sure there was no interference with any of the studs. Euro ports are about 40 - 41mm.
Are these the same headers from an 85 and 86 5 liter? I have a pair sitting around that I bought to install on my '84 4.7 liter engine. I was told they would fit by the same guy that made the y-pipe for me. Or are the ones I have different...?
