Oil Pan Gasket replacement
Team Owner
well figure you will also get an oil change/filter ,
and if they drop the cross member and do the motor mounts as well.about 1250.00
if you just drop the pan and the MMs are good then possibly about 350.00
Do yourself a favor and have the motor mounts replaced. You'll never needed to get down there again and you're only paying for the parts at this point. I didn't have it done and even though my mounts are still good, wish I had done it. Find a wrench that will put in the modified Volvo mounts (from 928sRus) and save big money.
