Cam Belt question
Hi I had my 84 s2 euro idling outside after moving it from the garage and after a few minutes there was a slight change in the sound of the car and I didn't think to much about it at the time. I then went for a drive and all seemed fine then the belt tension light came on so I carefully drove home. It has just had a new belt and was due to be retensioned so I will do this. My question is that if the belt ended up jumping a tooth would it be noticeable. Should I remove all the covers and check it all or would I know if it was out
