Getting out of 928's, would like to get a Cayman. I acquired this car from (KLVA) in 2009. it's a 1988 928S4, with Auto Trans. current mileage is 95794, everything has been sorted out. the body has no dings, dents or scratches, here is a list of things done at the 95245 mile mark.
cup ll wheels, (correct one's for a 928)
new Tires.
X-PIPE.
RMB.
P-Klamp installed. (thrust bearing checked=.006)
new front crank seal.
new oil pump seal.
new oil pump gear.
(2) new camshaft gears.
new timing belt.(GATES)
new water pump (Laso w/ plastic impeller)
new POR-KENSIONER belt tensioner.
new dist caps and rotors.
new a.c belt.
new p/s belt.
new oil fill neck gasket.
new water bridge gaskets.
new thermostant 75 deg.
new fuel lines.
new fuel filter.
new crank position sensor.
new upper and lower rad hoses.
new crossover hose.
have Porsche Certificate of Authenticity for this car.
asking $18,500
Thank you
Jerry
Sorry to hear that you are getting out of the 928 owners club, the truth is that you never really get out, just taking a break.... No one gets their 928 to that level unless they have it in their DNA.
Like Schwarzenegger said...."I'll be back"
