Advice for removing rear spoiler
Just bought a 79 Euro that the owner put on an early 80's rear spoiler. Said he used double sided tape instead of drilling holes.
What would be the easiest way to remove the spoiler without harming the paint and window trim. Was thinking of something like 3M adhesive remover.
Thanks in advance, Eric
Hi Erick, I was thinking maybe some mono filament fishing line and cut the tape up close to the Spoiler then deal w/ the glue.
Hopefully someone can offer up their experience and or suggestions
Dave
Dave
Assuming standard, double-sided, foam-core, trim tape, I agree - pull a fishing line or dental floss through to start cutting the tape core while gently levering up the spoiler using a plastic trim tool.
To deal with the glue and torn tape remaining, soak in PB Blaster, WD40 or something like Goo Gone - a couple of hours of soaking versus a few minutes makes a huge difference to the ease of removal in my experience.
Consider yourself luckiy!. The PO or the first owner (PPO) of my car drilled some ugly holes to fix the rear spoiler. Someday I need a hatch without, but nowadays they seem to be made out of solid gold
You might warm the area with a hair dryer before employing the fishing line, but don't overdo it. Also, some of the thinner braided line might be softer on the paint than monofilament. Bass Pro Shop or Cabela's will have plenty of choices. Good luck!
soak the double sided tape as best you can with wd-40. reapply once or twice over the course of a couple of days (if your not driving the car) and use the monofilament to "saw" through it after it softens a bit. the wd-40 wont harm the pain and is not as hazardous to rubber as some solvents.
Administrator - "Tyson"
+1 on the WD-40 and using some heat.
Take your time and it should all come off without any damage.
Some of the 3M double sided tape is so strong you could tow the car by the spoiler.
I've seen it used for fast repairs on race cars body panels.
Former Vendor
http://www.summitracing.com/parts/sum-up403
No additional cleaning is required to prevent damage. I use it so much I bought a dedicated pump-style spray bottle. I bought one from Summit but you can find a similarly functioning one from Home Depot for a fraction of the price. Impulse purchases never result in the best deal...
http://www.summitracing.com/parts/ucp-70305
http://www.homedepot.com/p/RL-Flo-Ma...56HD/100164531
