Cheap water pump?
#46
GREAT NEWS!
There's an even cheaper 928 water pump at http://tinyurl.com/oswdwow
Higher quarity, too. Just to eliminate risk, I might install two of them.
#47
FACTS:
The first seller has sold more than 50 of these '78-86 pumps on just his current eBay listing, and wrote to me that he has had zero complaints or problems. Other online sellers are doing similarly with this "cast iron" pump. There are sellers offering the '87-95 pump at similarly low prices, and one seller (with over 1.6M positive feedbacks on eBay for various cheaper parts) offers a 10 year guarantee of the pump itself.
CONCLUSION:
Hundreds of 928s have been fitted with this class of product, comprising a statistically valid sample.
QUESTIONS:
1. What evidence is there that those cheap pumps are more likely to fail than expensive ones?
2. If those pumps are failure-prone, why hasn't news of the problem reached this group?
3. If those pumps destroy engines, why are used parts so expensive?
4. How many subscribers to this forum are using those pumps, and don't know it?
5. How many Porsche mechs install these pumps and charge for the more costly ones?
I've ordered a pump. I have a lab, and if someone nearby has one of the expensive pumps we can do comparative microscopic, metallurgical, dye-penetrant, bearing friction, noise/vibration when spun, and other analyses.
(shields on!)
CONCLUSION:
QUESTIONS:
(shields on!)
#48
Administrator - "Tyson"
Bottom line is many are taking the safe route. As long as the impeller is plastic, worst case scenario you are on the side of the road with an overheating 928, not a damaged engine block by a metal impeller.
If these cheap pumps had a plastic impeller it would be a different story.
Personally I'm going with known history that I've been able to gather and that is water pumps rebuild by Dick Jordan were some of the best ever available (he retired a few years ago...).
I found a cache of 8 sitting on a shelf somewhere and bought them all, yes they have a metal impeller. Once I'm through this stash I'm not sure what I'm going to use next.
One of his former employees recently opened up shop and is once again rebuilding 928 pumps. I'm hoping his quality and choice of bearings is on par with (or exceeds) the Jordan rebuilds.
#49
Shameful Thread Killer
FACTS:
CONCLUSION:
QUESTIONS:
(shields on!)
CONCLUSION:
QUESTIONS:
(shields on!)
OBTW, conclusions usually come after Q&A, but maybe you work for the fedguv where facts and answers really aren't important.
#50
FACTS:
CONCLUSION:
QUESTIONS:
(shields on!)
CONCLUSION:
QUESTIONS:
(shields on!)
Hell, we have one local owner who drove to Frenzy and had to have his car flat bedded back to Texas because the metal impeller on that pump just stopped spinning.
Like I tell my customers, use whatever pump you want to on your car but do not expect me to install it. If the price of a quality water pump is too much for someone, they need to not own a Porsche 928.
#51
When exhaust valves cost $200 each, like they do for the S3s, my risk tolerance is pretty low for no-name parts that can break the timing belt.
Can't wait to hear how it works out for you, though.
#53
#55
If price alone, rather than failure rate, determines your opinion of water pump reliability, you should LOVE this one at more than $1,000! How can it not be superior to those cheapo Laso units?
http://tinyurl.com/ogry5ks
#56
What's your angle here? Just trying to shake things up? Self-deprecating username aside, you seem to be looking for arguments left and right since you showed up.
Who says they only install expensive pumps based on cost? I've never seen a recommendation for a pump beyond the factory, Laso, or Geba. Those are all name brand pumps.
#58
Being a cheap bas,,,, well - I'd go ahead and put any POS pump on a non-interference engine. Just plan on R&R every year or two. Broke pump?, tow it home, jack it up and get out the air ratchet. bzzzztz, bzzzzt, bzzzzzzt.
#59
#60
how about mine?? ill sell it for 50 bucks.. its genuine porsche too! a little rusty, but should work... no JIM, that didnt come off my car...it came off the devek 4.5 racer of petty's ugly!!! NO wait.. the euro 4.7 donor engine.... very ugly!
