Windows & Sunroof stopped Working..Help
Power through fuse 31 of the CE panel a Red/Black line goes to pin 7 on what looks like harness III on the control box. Pin 5 of what looks like harness I is a Brown/White which means it is a switched ground and this goes to the Interior Light Relay. The Wiring Diagram online is a little fuzzy to view. Google the 'ligeti 928' and the lines are on Sheet 3 of the Wiring Diagrams.
Add: Here's a link to a primer that will help you interpret the Wiring Diagrams.
http://www.928-electrics.com/Docs1/P...WDP%20Only.pdf
Wow...Alan is a friggin legend. When it's available I will buy it just to support him in his efforts. What a massive contribution to the 928 community.
Ok, some success. Found the alarm had a relay for same reason connected to K24 of the CE. I've replaced the relay and now the windows work, sunroof doesn't and engine fans run. I am thinking that the other side of the relay is connected incorrectly. The wire runs behind the CE panel so I'll have to pull the CE panel forward and see what's going on.
And thanks to Alan for the primer. It helped out big time.
