928 Forum 1978-1995
Sponsored by: 928 Specialists
Windows & Sunroof stopped Working..Help
Old 10-27-2015, 01:51 AM
DeWolf
DeWolf's Avatar
Default Windows & Sunroof stopped Working..Help
Hi Guys,
Can't seem to figure out whats going on. It's a 1990 model and the windows and sunroof just stopped working. Fuse is ok and tested good but I replaced it anyway. Does the window control under the seat operate the sunroof as well? I noticed after buying the car that if my wife and I went to put the windows down at the same time one would stop. Something is amiss.
Old 10-27-2015, 03:22 AM
MainePorsche
MainePorsche's Avatar
Yes, on your MY there is a Power Window/Sunroof Control Unit. I am unfamiliar with debugging window/sunroof issue(s) that have this control unit. Others will be chime in.
Best Wishes
Old 10-29-2015, 01:32 AM
MainePorsche
Bump for this fellow.
Sounds like he's having a tough go by some of his postings in Bill Ball's 90 S4 Window thread.
Old 10-29-2015, 01:56 AM
MainePorsche
Just throwing some old threads here. Maybe you'll find a pearl somewhere that'll help.
https://rennlist.com/forums/928-foru...oof+controller
Old 10-29-2015, 06:11 AM
DeWolf
DeWolf's Avatar
Yeh thanks mate, I've been through those as well.
Old 10-29-2015, 06:41 AM
Schocki
Schocki's Avatar
Do you hear a faint clicking from under your seat when you are pressing the window or sunroof buttons?
Have you tried to lock the car from the outside (driver side) and close the windows with the key from the outside?
Edit: BTW yes, the little black box controlls the sunroof too.
Old 10-29-2015, 07:02 AM
DeWolf
DeWolf's Avatar
Yes I've pulled the controller out and can hear the relays clicking when I press the window and roof buttons. Just can't work out why I only have 2.6V where it should be 12V. Don't even know where to begin to look.
Old 10-29-2015, 07:44 AM
Schocki
Schocki's Avatar
The relay contacts inside are spotless clean? Take a close look, often you will see pitting on the contact surface.
Old 10-29-2015, 08:50 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,550 Likes on 1,430 Posts
take the controller box apart,
put deoxit 100 on the contacts,
let the box sit for a few hours, also put deoxit on the fuses,
and then try the unit
Old 10-29-2015, 09:02 AM
DeWolf
DeWolf's Avatar
^ I'll give that a try tomorrow. This is first 928 I've had that has given me any trouble at all. Mongrel of a thing!
Old 10-29-2015, 10:38 PM
Alan
Electron Wrangler
Alan's Avatar
You did replace fuse #31 correct? check that you get 12V+on the bottom fuse terminal, probe into the open dimple on the body down to the fuse blade with it still in place
Alan
Old 10-30-2015, 12:33 AM
DeWolf
DeWolf's Avatar
Thanks Alan, I will try when I get home.
Old 10-30-2015, 05:31 AM
DeWolf
DeWolf's Avatar
Ok, have 12V at the bottom of the fuse. I should add that the car has had an alarm fitted and remote central locking. The PO said he has never had an issue with it. It was installed by Bruce Buchanan.
Old 10-30-2015, 02:10 PM
MainePorsche
Originally Posted by DeWolf
...I should add that the car has had an alarm fitted and remote central locking...
Hmmm...
You could have three complicated solar systems colliding in an already complicated universe...
It is good that Alan has been here, and is aware of your thread.
Old 10-30-2015, 06:12 PM
soontobered84
soontobered84's Avatar
Are we not thinking RELAY at all here gentlemen?
Nevermind.
I answered my own question after I posted. There doesn't appear to be a relay for the sunroof and windows as there is in the earlier cars.
Quick Reply: Windows & Sunroof stopped Working..Help
