EBC brake rotors - cross drilled or not?
My 928 4.5L has standard rear disc brakes and S version front disc setup. I am now at the point of buying the discs. I can buy EBC discs for a good price now. Full set front & rear with pads: EUR 745 or just the fronts: EUR 425. These are called "sport brakes"for whatever reason. I think they are cross drilled.
Alternatively I am offered EBC discs (I think standard, not cross drilled) without pads, front and rear for EUR 485 or EUR 319 just the fronts.
Are the cross drilled rotors worth the extra money? And should I buy the pads as well? I already have a new set of Pagid for the rears and Guttmann for the fronts on the shelf.
I don't like cross drilled rotors. For the street they look "cool" and really don't serve much of a purpose.
On the track they tend to crack and/or make the rotor wear uneven.
They were invented for racing where disks see maybe one full race and not more. Since street car owners want "race" stuff they are popular. In reality they only cause problems and don't bring any benefits compared to other options. Grooved disks would be much better for normal street and track day use but they are not as sexy.
the best stopping power occurs with a flat disc, no grooves or drilled holes. It's all about surface area. Plus they last longer.
I have three years and 10k on my slotted and drilled rotors with no issues. I actually use the same brand on our Honda Odyssey that chews through factory rotors, these rotors have been the only ones that have lasted any time without warping.
The theory behind holes or slots is the removal of hot gasses, to allow for cooler brake temps.
My 2 cents.
My 2 cents.
So many brake experts!
The holes look cool and if your wheels show them then I'd get them. Because of cool.
Getting sets can be a cost-saver but price it out for what you want.
My 2 cents.
My 2 cents.
If rotors are being eatn thru, its the pads. If you think they are warped, its just pad deposits from being out of temperature range.
Now back to Porsche related content. I think they look cool, and for the amount I drive the car it works fine. But I do agree with others on the flat rotors lasting longer. Especially if you are driving daily, or in the winter.
Captain Obvious
Super User
Super User
I have a neighbour's Pontiac Torrent that regardless how many high speed emergency stops I tried to do to scrub off the pad deposit, it didn't make a difference. One of the front rotors are causing a vibration when the brakes are applied at highway speeds. I'm starting to think the rotor (6months old) is actually warped.
