interior lights dont work?
driving home today at night for the first time in this 1981 928 and noticed that none of the interior lights work..(cluster/*****/center console) nothing at all.... im going to check the fuses tomorrow but i remember checking them before and they all seemed fine.. or is this a common issue with these cars with some wacky reason.... bad ground?
These bulbs are fed with Black/Blue wires which come off you dimmer switch. Two Black/Blues come off this rheostat. The rheostat (dimmer) is fed by a single Black wire for its power. They are simply attached to the rheostat by spades. Check this.
i looked for a dimmer and couldnt find one.. is it the **** on the left side of the seat next to the e-brake handle? i thought that was a volume **** for the rear speakers!! hahaha my blaupunkt radio turns on but there no noise coming from the speakers at any volume.. hmm
The dimmer wheels is under the dash. Use your left hand and raise it to a point above your left knee while sitting in the seat. Slide it across the border and you should feel the wheel. You'll have to get upside down on your back or spend time with a mirror to inspect the wire attachments. It's a similar wheel to your intermittent wiper speed adjustment, except it's on the left side.
You can call me Otis
