windshield trim removal??
There are supposed to be black plastic clips that fit over the rib the side trim slides on to. They are about 4 mm x 7mm and U shaped. Each leg of the U is a little thinner than a credit card. I would try to reproduce them or maybe try some really thin double sided grey auto trim tape.
Cheers,
thanks guys.
Funny how your mind works sometimes. I jumped right to the conclusion that those clips would not be in PET. Thanks for the reality check Jim.
If you tread lightly, the side trims can be massaged a bit if they are bent. They are not as fragile as the top strip, which is bitch to align from side to side.
I did tap gently with a rubber mallet and wood, and got it pretty straight. It sits better on there, but there were only 2 clips, so I need 2 more (actually, 4 - I'll pull off the old 2 and discard).
