Replace cog wheel on Potentiometer in HVAC Unit
Has anyone got a source for replacing this plastic cog from within the HVAC unit? Mine has split. It is a 28 mm wheel with 38 teeth and has a 4 mm d-shaped shaft hole.
So far my internet research has not come up with a near replacement.
i will be able to look today..
No worries shipping is cheap..
i would gladly send it as others here have helped me so i am always glad when i can pay it forward.
I split one probably 5 years ago. I just superglued it back together and have had no issues whatsoever.
Just make sure the glue is dry when you put the cog back on the shaft.
Looks like I Was mistaken.
Turns out i had two of the cog wheels that go under the fan speed switch...
I saw two cogwheels in the box and thought one was the one you were looking for...
Sorry to get your hopes up...
