Window Stuck
Hello. My passenger side window was stuck in the closed position. When I tried the switch, I would hear a faint rumble from the passenger door but the window wouldn't move. I tried pressing again the next day and after a few attempts, the window opened fully and then didn't move again. I thought the switch was ok since it was activating something in the door when depressed (I could be wrong). I took apart the door to check the regulator and motor but am not sure how to remove it. Is it just held on with the bolts to the inner door structure? Are there any write ups out there showing how to get regulator and motor out of the door?
Thank in advance.
Thank in advance.
I's best to clamp the window in the mid to up position, then remove the wiring plug from the motor, pulls straight out, then remove the four bolts holding the motor/regulator to the door, the arm will slide out for the window lower channel.
Thanks for the tip. Got it out in one piece. The connectors were a little corroded so I cleaned them good. Was hoping it was a conductivity issue but didn't work. I advice in where to go from here?
