Broke ribbon circuit holder. Fix please. So bummed.
Broke the pointed leg on left side bottom ribbon circuit holder of the instrument cluster. I can use some help on this last thing after repairing the steering shaft bearings and shaft. What a job that was.
Any chance I can replace this ? Universal clip of some sort? Thanks for the help.
I broke the long portion off of one of mine.
The short hook part that pivots is still functional, as it locks automatically, just a little difficult to unlock , need to use a small pick to release it.
Edit...
I just took another look at you pic, that's a different type connector than I described.
It is available for a few $. I usually keep them in stock.
I am using this with good effect for broken plastic parts. It is useful to put material both in the gap and reinforce it from the outside (if not visible).
Being from Africa, you have to be resourceful when on safari.
One time in the Congo, my radiator split open from the heat. Total despair. A cattle herder eventually came by to help. He asked me for the equivalent of 10 cents to buy materials to repair the radiator. As no other offers were forthcoming, I took him up on it. At least it would be amusing.
Several hours later, he showed up with a tube of superglue and cement dust. Mixed a bit of it together on the radiator damage. Voila. Total repair. Got some water from a mud-hole, filtered it through a sock, then drove for 3 days to civilization. Went to a fundi shop to remove the repair, but we could not. So, several years later, its still holding.
What does this rant have to do with Q-Bond? Well, I was in the states last year. Noticed it on a shelf. It's made in good old South Africa. What is it? Superglue and cement dust (or its equivalent).
