Pronounced "tick" from the fuel system. 86.5 S
I was hunting around under the hood with my stethoscope,looking for the source of ticking sound that i always assumed was the lifters. Turns out its most pronounced from the fuel rails. Regulators,dampers or ?
Team Owner
thats the fuel injectors they are hidden behind the fuel rail skirts
Sometimes vacuum leaks can sound like a ticking but sounds like you have it isolated. Can you further isolate to one inejctor/cylinder, or is it uniform?
Would absolutely not worry if the latter is the case.
If you have other symptoms, I'd think about checking fuel pressure, and then injector flow (which would require pulling them/sending them out).
