Amazing
I dropped the 928 habit in 2010 while the construction industry burned to the ground and just picked it back up
Went to start the first one, started right up. Amazing.
Had to jump the solenoid on the second one but it started right up.
Amazing.
I will now proceed to burn through piles of cash.
Amazing.
LMAO dd. What did you get?
Same 928s we've had for a while. #1 is a 78 USA, #2 is a 79 EURO.
#2 has an M28/11 that it will be giving up for #1
I did in fact, take a video of #2's resurrection. It blew a bunch of rust out of the tail pipe, has some lifter (or follower) noise for a while, but settled into a nice purr. Can't seem to coax the vid out of my phone and onto this post though.
It has that accelerator induced bog though, much like a carb with a bad accelerator pump. I forgot what causes that with KJet.
I know from experience that turning the ignition key on a 928 is a little worse than a boat and not quite as bad as an airplane, but a healthy cash injection will help the rehabilitation process.
Seems like money CAN buy you love after all.
