928 Forum 1978-1995
Sponsored by: 928 Specialists
Techron
Old Sep 18, 2003 | 03:17 PM
clutchpopper's Avatar
clutchpopper
Default Techron
I know that the PTFE based oil additives are bad but what are your opinions on using the Chevron Techron fuel injector cleaner for the 928?
Old Sep 18, 2003 | 03:25 PM
ViribusUnits's Avatar
ViribusUnits
Chevron is the only fuel additive that Porsche recomends, at all, so it can't be bad.
Chevron with Techron has been reported to some major improvements on various cars, includeing 928s.
If your haveing EFI issues, it's worth a shot.
Old Sep 18, 2003 | 03:36 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Techron goes great with vodka, and a hint of lime.
Old Sep 18, 2003 | 05:01 PM
Mark's Avatar
Mark
I use a bottle every 4 fillups!
Old Sep 18, 2003 | 07:01 PM
morganabowen's Avatar
morganabowen
Cool
I use a bottle about once a month I fill up with Chevron all the time
Old Sep 18, 2003 | 11:23 PM
Drewster67's Avatar
Drewster67
Chevron is the ONLY gas I ever use (Unless in a pinch or at the track) - As as matter of fact - I bought a quart of their 10w40 motor oil ,today, for the first time @ 2.09 a quart. Can't tell you anything else than that.
What I can tell you, is that when I changed my plugs, I did a visual of my pistons - One word describes it all ---- CLLLEEEEAAAANNNN.
You can't go wrong w/Chevron Products.
Old Sep 19, 2003 | 01:56 AM
DoubleNutz's Avatar
DoubleNutz
USMarine
Default Re: Techron
Once a month in this baby...
Old Sep 19, 2003 | 12:55 PM
John..'s Avatar
John..
Techron is great stuff. I use it regularly without issue. You might also try sea foam it is supposed to be very good.
Old Sep 19, 2003 | 03:36 PM
Sean79 5spd's Avatar
Sean79 5spd
I only use Chevron in my three vehicles. The Shark gets a bottle of techron every couple of months.
Sean
Old Sep 20, 2003 | 09:53 PM
Rufus Sanders's Avatar
Rufus Sanders
DoubleNutz, that's one gorgeous 996. Make me almost want to... um.. sorry, Never Mind, I almost said a bad thing, but hey, YOU did it didn't you???? - Ruf
Old Sep 20, 2003 | 10:16 PM
Normy's Avatar
Normy
Go out to a drag strip. Ask the kid with baggy jeans next to the turbocharged Civic what is in his tank. Then find the 40 something with a pony tail and a '70 Chevelle with a "496" under the hood what he has in the tank.
Then find scrawny Normy out there with his 928. I'm in baggy jeans and a T-shirt that says something rude too, but I keep my hair pretty normal [well, I dye it because I'm getting sooo gray!], and I wear earrings occasionally. Sniff my tank? What's in there?
The answer will be the same....Chevron.
N!
Rufus- there's nothing wrong with lusting about the boy's 996. Just make sure you keep your 928-
Old Sep 21, 2003 | 10:57 AM
DoubleNutz's Avatar
DoubleNutz
USMarine
Thanks Ruf, I a have been looking for several years to get back into 928 but have not found the one I would buy yet but, I am not giving up my passion to drive Porsche so 996C4 it is...today!
