928 Forum 1978-1995
Sponsored by: 928 Specialists
Used headers $200 a pair
Old Aug 24, 2015 | 04:10 PM
Mark Anderson's Avatar
Mark Anderson
The Parts Whisperer
Default Used headers $200 a pair
I have 2 sets of used headers. Unfortunately I cannot tell you which 928 they fit other that neither are for 87-95
File Type: jpg
File Type: jpg
Old Aug 24, 2015 | 04:24 PM
AO's Avatar
AO
Supercharged
The lighter set looks to be MSDS for a 16v. Not sure about the others... Good price. Worth a roll of the dice for someone. I already have headers on all my cars, otherwise I would get them.
Old Aug 24, 2015 | 04:47 PM
z driver 88t's Avatar
z driver 88t
Wow. The width of the darker set almost looks like you could drop the bell housing without loosening the headers. I've never seen those. Seems like a hell of good deal on either one.
Old Aug 24, 2015 | 05:20 PM
Mark Anderson
The Parts Whisperer
That's why I think those are 85-86
Old Aug 24, 2015 | 05:21 PM
EMan 928's Avatar
EMan 928
If one of these would fit a 85 Euro, I would be interested.
Old Aug 24, 2015 | 05:24 PM
Mark Anderson
The Parts Whisperer
I believe the lighter colored set will fit a 1985 euro 2v
Old Aug 24, 2015 | 06:22 PM
z driver 88t
Mark, in terms of what will "fit" my understanding has always been the two bolt flange fits any 16V engine but would require some custom fabrication of a Y-pipe or connector. Is that incorrect? I had assumed this was true since 16V guys bolt up the 85/86 stainless manifolds with minor modifications.
Old Aug 24, 2015 | 06:26 PM
Ad0911's Avatar
Ad0911
If shipping and import taxes wasn't so crazy for stuff coming from the US into the Netherlands, at least one of these sets (preferably dark set) would be mine now
Old Aug 24, 2015 | 07:14 PM
hlee96's Avatar
hlee96
Hi mark, looking for aftermarket headers for my '78 5spd. If they fit, I would like to purchase these from you. Also along the way, used 84-86 manifolds too as one shipment if possible. Let me know and I can call you to finish the transaction. My shipping address zip is 19317.
Last question, do you or roger sell the y pipes that would make these compatible with my future borla cat back system?
Thanks-Hoi
Old Aug 24, 2015 | 07:48 PM
Mark Anderson
The Parts Whisperer
Thanks-Hoi
Quote sent
Old Aug 24, 2015 | 07:56 PM
Mark Anderson
The Parts Whisperer
I've heard that but I cannot confirm
Old Aug 24, 2015 | 07:59 PM
mark kibort's Avatar
mark kibort
i have a y pipe going into a cat, from the headers that will bolt up to stock exhaust system, that will fit the 2 valve version. let me know if you are interested
Old Aug 24, 2015 | 10:45 PM
AO's Avatar
AO
Supercharged
Yes, these should fit any 16v car. However, they will require you to have the rest of the exhaust fabricated to take it from the flanges back to the tail fo the car. Any exhaust shop can do this for a reasonable sum depending on what kind of material you're looking for.
I think Carl might sell a setup to go from the MSDS headers to the back, but you'll have to check.
On my 85 Euro and the Coke car, I have MSDS headers that then mate into a Y then into a single 3.5" sewer pipe that make the care super loud and lots of fun to drive.
Old Aug 25, 2015 | 02:59 PM
vanster's Avatar
vanster
The lighter headers are the same ones that are on my '80. I know them well. The big PIA is when you need to pull the bottom half of the bell housing you have to unbolt the headers and pull them aside.
Any good muffler shop can connect them to a cat. I have never had a problem going thru smog cert with them. How much do they help? There seems to be a big debate on this, they do look cool and they do seem to alter the exhaust note somewhat.
Old Aug 25, 2015 | 03:30 PM
soontobered84's Avatar
soontobered84
My MSDS headers look more like the darker ones in the picture as the collectors are flush across at the end instead of ending at an angle as the lighter colored headers in the picture.
And yes, at least one header must be loosened to remove the lower bell housing. Maddening!!!
