928 Forum 1978-1995
Sponsored by: 928 Specialists
Black Trim Surrounding Lock
Old Jul 22, 2015 | 07:38 PM
gjpearce's Avatar
gjpearce
Default Black Trim Surrounding Lock
What is the best way to get rid of scratch marks on the black trim ring that surrounds the driver side door lock? I just installed remote control locks so I will not have to use a key ever again on that door.
Any advice is appreciated- please give name of any chemical product and best place to purchase
Old Jul 22, 2015 | 08:12 PM
fltechpilot's Avatar
fltechpilot
I just taped them off and repainted them in satin black. Painted them right on the car.
Old Jul 22, 2015 | 08:28 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Through the rearward end of the doors, pop off the top-most rubber cap and remove the socket head cap screw that holds the lock cylinder in place, and move the lock cylinder out from the door skin. Surround with painter's tape to protect, then clean up/buff with fine sand paper to smooth, then prime and repaint- self etching primer then SEM trim black:
Old Jul 22, 2015 | 08:59 PM
fltechpilot
Self etching primer is key. I made one attempt without it, anticipating that the old paint would be enough of a primer. I got absolutely no adherence. Attempt #2 with the self etch turned out great.
Old Jul 23, 2015 | 01:24 PM
NoVector's Avatar
NoVector
An alternative is the Jager sticker covers. I've had them on the car for at least 5 years now and still look as good as the day I put them on.
http://www.jageng.com/garage9/produc...products_id=77
File Type: jpg
Old Jul 23, 2015 | 02:51 PM
Chalkboss's Avatar
Chalkboss
The overlays are okay but they come as a "broken circle", so there is a seam. I got some and don't like them for this reason, I can see the seam, however slight. Bugs me.
I am going to paint the surround and the rest of the trim using the methods described in this thread.
Old Jul 24, 2015 | 11:44 PM
Petza914's Avatar
Petza914
I masked mine off with blue tape and then carefully cut around each with a razor blade. Painted them with matte black flexible battery corrosion prevention tray paint as it's pretty tough. I installed electric locks so the only lock that still sees a key is the rear trunk. Turned out very nice. There are pics of the car on a Shutterfly share site if you look in some of my other posts for the link - "Spyder Maiden Voyage" is probably the most unique thread title for quick search results.
Old Jul 24, 2015 | 11:47 PM
martinss's Avatar
martinss
As Rob noted, the trick is to move the lock cylinder forward so that you can mask under it.
