Engine harness swap questions. '88 5-speed harness in '89 GT.
My no spark issue turned out to be a bad crank pos sensor. I had replaced it because the original connector was starting to crumble. Cutting corners bit me in the butt because the cheapo FAE sensor I got for $50 was DOA right out of the box.
I swapped the old one in and it fired right up.
Team Owner
well that was easy,
FWIW I have found that using any electrical parts that are not Bosch in a 928 is a formula for a disabled machine.
Add heater valve to the list of parts not to cheap out on. The new Meyle valve I installed as preventative maintenance started leaking almost immediately and was quickly pouring out at least a gallon in 5 min.
At first I thought it was just normal burping air out of the system, but after adding 3 gallons after the initial fill and the ever increasing frequency of the "check coolant level" warning I knew there had to be a leak.
I swapped the old German made valve back in and no more leak.
Now the alternator isn't charging. 1 step forward, 2 steps back...
