Replacement keys
I was going to write this
"The keys are identical apart from the extra length with an extra tooth to deflect an extra tumbler in the alarm switch part of the lock( maybe two extra teeth can't remember) of the long key - so yes you can create a short key from a long key."
The simple answer is if you cut off the extra length from a working long key it will be a working short key.
I learned something here. So the shorty key just doesn't activate / deactivate the alarm? Any issue with using that one all the time?
What if you use the long key to lock, and try to unlock and start the car with the short one?
