Accessory Belt lengths?
What are the accessory belt lengths on the 86.5?
Ac, power steering p, and the belt that goes around the air pump and the fan?
They usually sell them in mm.
My 86.5
https://rennlist.com/forums/928-foru...l#post12289379
According to PET:
Air Pump = 12.5 x 1040
PS = 12.5 x 1000
AC = 12.5 x 1125
Alt = K6 858
According to PET:
PS = 12.5 x 1000
AC = 12.5 x 1125
Alt = K6 858
Basic Sponsor
Alternator - 858mm
PS - 1000mm
AC - 1125mm
AP - 1040mm - Option M319 - 1025mm
PS - 1000mm
AC - 1125mm
Thanks!
BELTS HOSES SEALS GASKETS
BC
this may be of some help for you and others
TIMING BELT 928 105 157 00 78 TO 82 SQ TOOTH
TIMING BELT 928 105 157 50 M21 83 TO 95 RND TOOTH
WATERPUMP 928 106 015 22 M59 78 TO 87
WATERPUMP GASKET 928 106 134 06 M260 ALL YEARS
WATERPUMP BELT 12.5 X 1040 MM ?78 ON ????
WATERPUMP BELT 999 192 160 50 M21 ?80 TO 86?????
UPPER RAD HOSE 928 106 238 06 M101 78 TO 84
UPPER RAD HOSE 928 106 238 08 M269 85 TO 95
LOWER RAD HOSE 928 106 239 08 M100 78 TO 86
LOWER RAD HOSE 928 106 239 09 M101 87 0N
TENSIONER ROLLER 928 105 571 00 M100 78 TO 82
TENSIONER ROLLER 928 105 571 020 M40 83 TO 86
TENSIONER ROLLER ON PUMP 928 105 512 12 M40 78 TO 95
THERMOSTAT 928 106 129 17 M2 ALL
TSTAT O RING 999 701 632 40 M213 ALL
TENSIONER BOOT 928 105 552 06 M100 83 , 84
ADAPTOR RUBBER FILLER 928 105 552 05
TENSIONER BOOT CLAMP 999 512 345 02 OEM 83 TO 95
TENSIONER BOOT CLAMP 999 512 322 02 OEM 78 TO 82
GREEN WIRE 928 602 907 00 M100
TENSIONER BUSHING 999 924 002 40 M100
AC BELT 12.5 X 1075 78,79
AC BELT 12.5 X 1125 80 TO 89
ALTERNATOR BELT 928 192 135 50 M21 GS
OIL PUMP ORING 999 701 633 40 M17 78 95
OIL FILLER GASKET 928 107 169 01 M17
OIL PUMP SEAL 999 113 275 40 M17 78 TO 95 20 X 30 X7
OIL DRAIN PLUG SEAL 900 123 118 30 M131 22 X27 MM NOT ALL THE SAME
13 M6 GRADE 8.8 BOLTS 900 378 030 OEM ( GRADE 10.9 BETTER) FOR WATERPUMP
FAN BELT 12.5 X 1040 MM
FAN BELT 999 192 117 50 M21 78 12.5 X 1050
ALTERNATOR BELT 928 192 135 50 M21 78 TO 81 9.5 X 875
ALTERNATOR BELT 928 192 214 50 M21 82 TO 83
ALTERNATOR BELT 928 192 120 50 80 TO 82 12.5 X 1025
ALTERNATOR BELT 928 192 347 50 M21 85 TO 89
TENSIONER GASKET 928 105 611 05 M17 85 ON
TENSIONER PUSH ROD 928 105 551 100
POWER STEERING BELT 999 192 286 50 M21 12.5 X 975 AND 12.5X 1000
CRANKSHAFT FRONT OIL SEAL 999 113 263 40 M17 ALL 60 X 85 X 10
CAMSHAFT SEAL 999 113 282 40 M17 ALL 30 X 47 X 7
CLUTCH FAN PULLEY
FRONT BEARING 928 102 111 02 M40 78 TO 86 6202 Z
REAR BEARING 928 106 441 05 OEM 78 TO 86 6301ZR
FAN BELT TENSION PULLEY BEARING 6002 2Z
OIL LEVEL SENDER GASKET 928 606 213 03 OEM
PS = 12.5 x 1000
AC = 12.5 x 1125
Alt = K6 858
CLUTCH FAN PULLEY
PS = 12.5 x 1000
AC = 12.5 x 1125
Alt = K6 858
