Engine size
Engine size
Have a -78 928 with no engine number on the block. It is stamped ATR. When a bought it, the seller said it was a refurbished engine from Porsche and that its not supposed to have a matching number.
The seller also said it is a 4,7ltr engine, but since the car did not come with any papers, I have no way to confirm this- maybe other than on a dyno or even measure the pistons.
Is there a alternative way to measure wheter I have a the 4,5 or 4,7 ltr engine ?
Pull the plug on #1 cylinder at TDC and fill the combustion chamber with oil, turn #1 to BDC and fill it again to the same mark. The amount of additional oil is the displacemant for one cylinder, X8 for the engine desplacement. A ballpark measurment, for sure, but it may give you some idea of the engine size. Don't forget to suck out the oil before you start the car...LOL
ATR is the stamping for a factory replacement block. My '87 has one too.
One possible way to identify which engine is the pistons - if you can get a good shot of the top of them with a small USB camera or endoscope, the size of the dish, valve reliefs etc. may give some information on which pistons are actually in there (coupled with the experience of someone like Erkka).
