MY 85 issues after some fixes, has trouble with kickdown.
Received 1,347 Likes
Not sure what a bad TPS would do but you can test it with a voltmeter.
https://rennlist.com/forums/928-foru...re-w-pics.html
Also, it needs to be well adjusted.
Are you sure the connection is good and well connected?
Just asking.
Good luck.
Just asking.
Good luck.
Just asking.
Good luck.
Just asking.
Good luck.
As far as the adjustment that is one thing I will have to confirm somehow, but I made sure not to move it at all since I did not want to go through this adjustments.
I will check that link you gave me, I gather it's for the voltage check, so I can make sure it's doing it's job.
