Hi all, found a small bit of coolant on the driveway and on the underside of the car. Front of the engine looks dry (replaced wp two years ago)
Any idea where this leak is coming from? Reservoir bottle maybe?
Or it could be one of the lines UNDER the reservoir. You have to remove the reservoir to get to them. Looks more like what Davek has already posted though.
When I looked under the reservoir from below all looked dry. I did replace the heater valve a while ago. Maybe it has a slow leak in the connections. I will take a look.
