rear suspension
Archive Gatekeeper
Is the torque tube still connected? Mount a heavy vise in the middle of a length of 2 x 10, and clamp the front TT shaft coupler in the vise. Put the transmission in 5th gear. Rent a 1" impact wrench and a 32 mm socket, and go to town. Or get a long 3/4" drive breaker bar and a 32 mm socket and have a friend counterhold a long steel bar between the wheel studs on the opposite hub.
Or am I fundamentally missing how the differential will (re)act in this situation?
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Team Owner
get an air gun and put the 32 MM impact socket on it,
spray the nut with PB blaster first ,
the nut should come right off
Took me three hours.
Impact guns have not worked for me but I do have the huge ones.
I heat up the nut.
I have someone counter hold a bar that fits between the studs.
I take a 4 foot breaker bar on a large ratchet handle and pull. Sometimes I break the craftsman, and then I get it fixed or replaced. Sometimes I get the nut off the first time.
I heat up the nut.
Archive Gatekeeper
The problem is the transmission is no longer there, he's suffering from floppy axle syndrome.
Borrow a transmission output axle flange from Roger (or Mark?), put three bolts through the axle one way, and three bolts through the flange the other way, bolted to something sturdy.
![](https://webfiles.uci.edu/redwards/public/Transmission%20to%20axle%20joint%20flange%205-27-15.jpg)
Then bust out the bigass breaker bar.
![](https://webfiles.uci.edu/redwards/public/3-4%20in%20breaker%20bar%20for%20928%20head%20bolts%205-31-14.jpg)
Archive Gatekeeper
'Cause that's a way simpler and more elegant suggestion than my Rube Goldberg.
Archive Gatekeeper
'Cause the rear suspension is sitting on the ground all floppy-like.
Archive Gatekeeper
The floppiness fixation is based on trying to see how to hold back a whole lot of torque with 2 CV joints that are going to want to twist on you unless they're more or less in line.
Mostly, though, I'm still trying to get my head around you not owning any air tools. They're the greatest thing since compressed air!
