Dash pod switch lamps...How to get ahold of the damn bulbs!
So I'm trying to replace my pod bulbs for the headlight switch,hazard button and such but I can get 4 of the bulbs out. I've tried everything from needle nose pliers, tweezers and everything in between.. What the hell was Porsche thinking!
Anyone have any tips?
Thx
Thx
I've used simple desktop office tape and tweezers... I cut a small strip of tape and wrap around bulb- sticky side to bulb 360º and then reverse with the same piece of tape, without cutting, and doing another 360º with sticky side away from bulb. Then use tweezers to pull.
No breaks so far- but man would I love to get the tubing trick to work!
It was late and I didnt have the tubing or sandpaper on hand so I just used a hot glue gun and dabbed a bit on each bulb, once it cooled I was able to pull them out easily.
The tubing works extremely well - if you get the right size - just take a bulb along and buy 1' flex clear vinyl thick wall tubing
Because it applies even all round pressure it has little risk of damage and the bulbs once removed are easy to wiggle out of the tube.
Alan
Alan
