Possible misfiring injectors
My 82, the engine starts fine and idles normally. Then after getting it on the street and accelerating, the engine feels like it was running on about 6 cylinders with hesitation and rough idle.
I brought it home, checked for a vacuum line disconnect and that all injectors and plug wires were firmly connected.
I pulled the Injector relay and disconnected the L Jet brain. Let it sit for a couple of minutes and then reconnected.
Car now runs fine with great acceleration. These symptoms have never happened before today, could the L Jet brain be going bad?
The FI relay is new, all ignition components are new, O2 sensor new. Injectors have been refurbed by Witch Hunter.
Personally, I don't get excited about one flare-up in running conditions. Especially, when one takes into consideration the fuel quality nowadays. Sure, it's always a good idea to stay on top of things...but I'd give it a couple more shakedown runs and see if it duplicates the same symptoms.
Not saying there may or may not be an issue...just don't go to crazy right off the bat.
Brian.
Brian.
