So now that my S4 is Supercharged I need to install a Afr and boost guage. I went ahead and purchased an Innovate PSB-1, it has AFR and boost in one unit.
Now I have to figure out a good place to mount it, so I'd luv to see pics of where others have installed theirs.
I think the most elegant solution is Jim Mayzurk's, in his '93 GTS (see Jim M.'s signature picture...) but there's only 1 of them, and it's in Jim's car.
The easier solution is an A-pillar gauge cluster, Carl sells a 2-hole and 3-hole cluster, can't find them on his site but they've gotta be there somewhere.
I'll have to take a look at Jims..Not real big on the A piller look seems a bit ricer, not to mention I don't know what I would fill the other spots with.
I have digital gauges, and placed them in the center vent of my Gt along with my Valentine 1 remote. Super clean. The issue with putting them low like Jim and other have done is you can't really look at them. The a-pilar... well you know what's all about.
Carl no longer has the A-pillar gauge holders available and isn't making any more. I had bought one of his last 2 last year and sent it to William Jewett in CA to be recovered and it's one of the things that fu--er kept and never sent me any parts. This was before I found Rob Budd.
I'm putting mine down in the ashtray area along with a couple of USB charging ports.
I pulled the ashtray insert/metal pat and then drilled 2 holes on the ashtray lid. Being so low, you have to make an effort to look at it but at least it's a clean instal. Sorry, can't post pictures because of Rennlist's screwed up rules.
