928 Forum 1978-1995
Sponsored by: 928 Specialists
AC prassure switch question
Old 05-15-2015, 01:27 AM
Ducman82
Ducman82's Avatar
this guy? number 17?
i do have my fan control set up to power up to half speed ish, when the AC is on, not counting the aux fan i just re added. but i like that other switch idea.... could have saved me some fab time.. LOL. i should be headed to gregs and marks tomorrow, so i can rummage around 928intl and see what i can find.
Old 05-15-2015, 03:07 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Jake--
Get the connector too.
And run the fans on high when the AC is on especially with R134a conversions. You may want to shop around for a combo pressure switch with a lower overpressure cutoff setting too. More than 350 psig gets to be too much in a hurry.
Old 05-16-2015, 01:12 AM
Ducman82
Ducman82's Avatar
from what i can tell the R12 nipples on the dryer pipe/tree are 7/16-20..... does anyone know what the thread on the pressure switch is... i think its m10x1.0
Old 05-16-2015, 11:59 AM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
I think that the best system is:
- Add a good relay to operate the compressor clutch, triggered by the original black wire;
- Add a second relay, triggered by the first one, to operate the fan or fans on high.
This can extend the life of the under-sized relay in the HVAC head unit, and gives better AC performance and longer system life by adding condenser cooling.
Old 05-16-2015, 01:23 PM
Ducman82
Ducman82's Avatar
the cool thing is i have manual HVAC i my car, so it has a nice big relay on the CE panel. but not a bad idea on the fan.
right now I'm searching for a trinary switch with a fitting that will work on the Drier pipe/stock fittings.
Old 05-16-2015, 06:09 PM
Ducman82
Ducman82's Avatar
found one with 30psi low pressure cut off, fan on at 195psi, and high cut off of 384.... think thats to low for the hight cut off?
Old 05-16-2015, 06:49 PM
Alan
Electron Wrangler
Alan's Avatar
R134a?
Alan
Old 05-16-2015, 07:12 PM
Ducman82
Ducman82's Avatar
yup
found this one, might be better
MT0381
http://fs1.omega-usa.com/SantechCatalog/#?page=124
Old 09-11-2015, 07:06 PM
Ducman82
Ducman82's Avatar
compressor has been cycling off and on at idle. I'm wondering if 384 is to low for a high cut off?
Old 09-11-2015, 07:18 PM
griffiths
griffiths's Avatar
When cycling off:
What is:
1) Ambient outside air temp?
2) High side pressure?
Old 09-11-2015, 07:23 PM
Ducman82
Ducman82's Avatar
ya, need to get me a gauge set.... i gave robs back. its 90 outside! that much i know .
Old 09-11-2015, 08:26 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
The high switch is 30 bar. 435psi.
Soo....I think thats within variance of what it could be accurate to.
Old 09-11-2015, 08:35 PM
Speedtoys
Speedtoys's Avatar
Stock switch is 2psi on the low side.
Quick Reply: AC prassure switch question
