Electrical Pop & No Start (but fixable) - what's happening?
OK. Quick narrative.
Rear plate lights burnt, corroded and not the right size.
Picked up a couple new ones ($22 total). Crimped new connectors to the wires, connected them to the new lights, had them dangling (not yet screwed in). Turn on ACC, flip on headlights, walk to the back of the car and yay...new plate lights are on.
Mount the lights to the frame, screw them in, flip the key to ACC and POP. Everything dead. Check fuses - all good.
Remove Battery ground, take lights out, put ground back on, turn key and I've got lights again.
So - where did the pop come from? I'm assuming I have something up in the cavity where the lights are that are touching the frame and the terminal on the lights, but why didn't a fuse pop? And why did the removal / reattachment of the ground fix it?
Ahh...love the new ownership here
i have had the sound of the arcing/sparks make a noise like that. but how it did not kill the fuse, no idea. are you talking about the rear interior lights? if so, i had to wrap the 12v connections in shrink wrap just to make sure.
Are you sure you have the right fuses in there? In other words, someone didn't stick one with a higher current rating to prevent it from blowing?
Thanks for the input, guys!
Electron Wrangler
Replace the battery ground strap
It was likely entirely coincidence and I expect unrelated to the work you did (unless you physically disturbed the ground strap).
Alan
Alan
Still think I should replace it?
So doing some reading and I see many other cases of good-looking cables that ultimately ended up causing problems. I think I shall invest in a new battery ground strap. On a related question does anyone have the length of the main engine ground strap?
Electron Wrangler
Call Roger to get the right thing - aftermarket is fine - may in fact be better - do wrap it airtight.
Alan
