Rear main seal replacement and...
Hi guys,
My question sort of drowned in another thread.
1. Do I have to drain the engiine oil before I replace the seal - the car istilted pretty good since only the front is raised. I dont want an oil mess in the garage
2. Would you put some of the special Porsche Opti spline grease between the TOB and fingers of the PP?
Have a great weekend,
Christian
Christian
Team Owner
you should not have to drain the oil,
if oil comes out then drain off about a 1 quart
Yes a lil bit of lube on the fingers wont hurt.
NOTE use a tooth brush to coat the splines of the discs and the stub shaft with the sticky hi temp grease
