928 S4 with 9.708 miles!!!
That is a bargain price. The Minerva sister car is for sale in Germany for appr. $135k.
Åke
http://suchen.mobile.de/fahrzeuge/de...ion=eyeCatcher
Åke
You can call me Otis
Åke
Åke
That's more like 2nd cousins over here.
No, the sister car to William´s and Rob Edward´s car named Minerva.
Åke
https://rennlist.com/forums/928-foru...t-arrived.html
Åke
Chronic Tool Dropper
S4 slots are not finished beyond the color of the aluminum. Some folks put black to hide staining from brake dust, but that is an owner modification. It's a chore keeping the area behind the slots clean and bright, since airflow draws the brake pad dust out through there. But that's how they were originally.
09 at the end is about to roll to the 10, and 97xx is getting close enough to 10000 that its starting to roll.
My '87 is currently doing the same at 199200km - all lined up perfectly before then.
Received 1,678 Likes
Plastic drive gear in the mechanical odo pre-'89. They all fail. They have all failed already. Or they are one trip odometer reset away from failing.
I consider any pre-'89 to be TMU (Total Mileage Unknown) until I see it with my own eyes.
On the flip side - my current 87 S4 from the UK has a completely working original cluster, and documented mileage to support.
Either the plastic used by Porsche was highly variable in quality (possibly multiple sources?) or something environmental has a major impact on gear longevity too.
Regardless, Dave's spot on - they have a finite lifetime, and the failure rate at 20 years old is very high, which means a lot either don't work, or have been apart and should only be trusted with adequate documentation.
I have always assumed that it's temperature and heat-cycling that kills the plastic - same as most other stuff that degrades for reasons not primary related to use.
Nevertheless, I still think it extremely likely that Porsche (and VW) didn't do anything to the odometers. They got a box of them from VDO, stuck them on a shelf, and pulled them out one at a time as they assembled cars. And thus, grease or no grease VDO is to blame.
